Hi, I’m l4 possibility to add instructions for an individual string. Like character limitation. I work with German - Korean language pair, so it’s important not to break the UI visibility.
There is a possibility to set up max.length directly in the Editor for each string
Or via Api
https://support.crowdin.com/api/v2/#operation/api.projects.strings.post
