We’ve run into an ambiguous situation when working with branches and uploading source files. Below are two scenarios:
1. Problematic case
In GitLab, create branch feature/X
In source file (e.g. en.json ), update the text for key MY_KEY
Run:
crowdin upload sources branch --branch feature/X
– this creates branch feature/X in Crowdin
Manually modify en.json and translation files in our code
Merge feature/X into main branch
From project root, run:
crowdin download
Result: downloaded files contain empty strings for the updated key instead of translations
2. Normal case (everything works)
In GitLab, create branch feature/Y
Run:
crowdin upload sources branch --branch feature/Y
– this creates branch feature/Y in Crowdin
In Crowdin’s UI, switch to branch feature/Y and add translations for the new text
Locally run:
crowdin download branch --branch feature/Y
– you see the new translations
Merge feature/Y into main
Run:
crowdin download
– all translations are pulled in correctly
Our questions
Master string when upload
How does Crowdin determine which translations/strings is “MASTER” when running crowdin upload sources (without --branch)?
Conflicting edits across branches
If the same string is modified in two different branches, how does Crowdin decide which version is “current” and which translations to download?
We’d appreciate any guidance on how to keep our workflow consistent and avoid losing translations.
How does Crowdin determine the “MASTER” string when running crowdin upload sources (without --branch)?
The first string uploaded into the project is considered a master, regardless of whether it’s a development or master branch. If it is deleted, then 2nd uploaded will become the master and so on.
When you run crowdin upload sources without specifying a branch, Crowdin will upload source strings as it is written in your source path (CLI configuration) into root/master.
Crowdin handles strings in different branches as separate entities tied to their respective branches. There isn’t an automatic “conflict resolution” that merges translations across branches into the main branch.
If a string is updated in feature/X and translated there, those translations belong to feature/X in Crowdin. When you merge feature/X into your local main and then crowdin upload sources to Crowdin’s main branch, the new source string appears in Crowdin’s main branch.
Working with duplicates in Crowdin can help here. Just enable duplicate management in your Crowdin project settings (look under “Import”).
Choosing “Show within a version branch (regular detection)” or “Hide (regular detection)” is key. Combined with a good Translation Memory (if needed), it is highly effective for your branching workflow, preventing those “empty string” issues.
This is clear, but if we do that and run crowdin download in the main branch right after, we get translations from feature/X branch. If these strings were translated in feature/X branch in crowdin and not in main branch in crowdin, how does crowdin connect it and downloads correct translations?
e.g.
(git) feature/X – change source string from "key": "initial value" to "key": "new value"
run crowdin upload sources --branch feature/X
(crowdin) feature/X – add translations for language FR for “new value”
(git) merge feature/X into main
run crowdin upload sources (now we update source string in maincrowdin branch based on our maingit branch value that we got from feature/Xgit branch)
this gives us new correct translations for FR language with translated “new value”
this behavior is expected, but we don’t understand what leads to it, cause we didn’t translate the new value of the source string to FR language in main crowdin branch. How crowdin knows that it should take FR translation for "key": "new value" from feature/X crowdin branch when we run crowdin download after updating only sources in the main branch?
Duplicates or TM pre translation may result in this.
If the key is translated even once (translations for language FR for “new value”), following duplicates/tm logic, this translation will be applied to any similar key within the project.
Alternatively, you might have uploaded both translation and source, in case you merged branches in Github. The connector support translation upload as well.
