How does ''continious fine tuning'' app work?
Hi, I downloaded the ‘continious fine tuning’ app from the Crowdin store and installed it.
But I couldn’t understand exactly how it works.
I mean, for example, if I confirm any string, it will go to the translation memory and then the fine-tuning process will start immediately?
Hi @egmnshnky the app will run fine-tuning every 4 hours (gather all the new content you got during that time) and it needs more than one translation to run the fine-tuning
so after you create the fine-tuning job and it’s done, the app will monitor it and after around 4 hours it will retrain the model to ensure it stays optimized without manual input.
Basically, it makes sure your AI is always learning and staying fresh without any extra effort from you
