How can I automatically translate a .json into 200 languages
how can I automatically translate a .json into 200 languages? Translating a .json into 200 languages by hand is a significant undertaking
Hello @trainvscar!
Sure, you can, but you need a proper setup for this.
If you’d like to auto-translate the file, you can do it with Machine Translation or AI. But it’s important to note that MTs have a limited number of target languages they can support, so you need to first check the engines. Here you can find more about how to connect MT.
As for the AI, it can offer more features, but you also need to check the provider first and their plans to see if they suit your needs. Here’s how to connect it.
