Hiding left pane "Search in"
Hi,
How do I hide the left pane “Search Files”?
Thanks
Hi @evdoxia.renta
By pressing the Strings button, you’ll be switched to the strings view instead of searching files. It is also possible to change the editor layout with the Show/Hide panel button at the top right, kindly check the screenshot below:
