I have Crowidn set up with GitHub integration. I have both Portoguese and Portoguese Brazilian as languages. I set up a custom language mapping that maps Portoguese Brazilian two_letter_code to “br”.
As a result, in my GitHub repo I can see the pt.yml file for Portoguese and br.yml file for Portoguese Brazilian. The problem is that, inside these files, both have “pt:” at the top; instead, I’d like Portoguese Brazilian to have either “pt-BR:” or “br:”.
How can I achieve that? Thank you in advance
Here is my crowdin.yml config:
"files": [
"source": "/config/locales/en.yml",
"translation": "/config/locales/%two_letters_code%.yml"
"source": "/config/locales/devise/devise.en.yml",
"translation": "/config/locales/devise/devise.%two_letters_code%.yml"
"source": "/config/locales/backend/backend.en.yml",
"translation": "/config/locales/backend/backend.%two_letters_code%.yml"
