Hi folks,
I saw on your platform that you’ve started to support Google Drive but I cannot find it in my Integrations tab. I assume it should be there, is that plan limits or what?
Hi folks,
Hello Richard,
You may find the Google Drive integration in the resources tab, full path: upper left corner → resources–> marketplace:
Also, you’re welcome to check the Crowdin store, here you can see all applications and their specifications: Google Drive – crowdin-apps
@Denisque it was very helpful! Thank you
You’re welcome as always
