A number of translations have been updated by the Github integration and I don’t know how to solve it.
e.g. Crowdin
Shows Bir Evrensel Kablo üretin in Crowdin, but has not updated on the PR
Original file: Mekanism/src/main/resources/assets/mekanism/lang/tr_tr.json at 1.21.x · mekanism/Mekanism · GitHub
TaniaM
2
Hi @thiakil ,
I can see that the integration is paused. Could you please resume it so that the changes would sync to your repo?
Hiya, I decided after this to migrate to Enterprise open source, and have re-setup the integration there.
Apologies
Iliana
4
Hi @thiakil
Thanks for the update, and no problem at all!
If you have any questions about the new setup, we’re always happy to help.
