Ghost integration hangs
After getting the Ghost integration to work on a /dev site I’m now trying to use it on production.
I updated the url and it now hangs
It said 'check expiration of the token.
Hello @sam_uk
Are you using this integration? Can you confirm you’ve followed this guide step-by-step?
Perhaps re-generating the access token will help, have you tried it?
Yes I am using that guide.
The first actual step is 'Import your website content from Ghost.org. ’ that is where it fails. It will not import.
Where do I need to put the access token please? I don’t see that in the guide?
Hmm, I’m afraid we will need additional details in order to check everything.
I’ve sent you a direct message in order to solve this issue faster and privately.
I’m not seeing a DM yet?
Checking back it does seem to have done something
But of course I don’t actually see ‘undefined’ there
The DM should be received by now, as well as the follow-up email.
