Hello, google drive connectors seems to not working properly. I can use files from shared folders. Only from the one I own. It’s not acceptable because all my team work in a shared folders. Can this be solved?
Actually, you can use files from shared folders. Need to be changed a settings of integration. Integration - g drive - settings - allow to use files from shared file (may be differently called but it’s the only option there, you won’t misclick).
