I’m trying to add glossary terms for Minecraft’s formatting and color codes:
I’ve added a couple, but they’re not recognized (not underlined with a tooltip in the editor); I suspect this is because a space doesn’t separate them from other words.
I’ve tried changing the “Part of speech” and “Type” settings for the terms, but I haven’t found a combination that works.
Hi @supersaiyansubtlety , could you please kindly share your glossary file and record the video for us with all the steps on how you upload it, configure it and open in the Editor?
It looks like the original string belongs to a file for translation (eu_us.json), not a glossary file, and it looks like this string contains no terms. Please make a short screencast so can follow your actions step by step.
As for downloading the glossary, it can be done from the Glossary tab, 3 bullets near the needed glossary
The string I link to in the OP is one that contains “§n” and “§r” which I’m trying to create terms for, but they’re not recognized as terms in that string.
Unfortunately, it is expected behaviour. Due to technical limitations currently, it is not possible to handle the formatting directly in Crowdin. In some file formats such as XML, XLF for example the following formatting is supported: <b> text <b>
