I have folders in my project for various different pages across the site (see untonemusic dashboard in Crowdin) - they show up on the interface, and can be translated. But when the project is built (whether through crowdin pull or through the online interface), the translations, json files, and folders as a whole are entirely absent.
Hi @ArchieW ,
As far as I can see from our database, all files are successfully exported. If you want to preserve the same structure of folders on export as well, you can add the %original_path% placeholder to your export pattern path (Sources tab → three dots next to the needed file → Settings → Resulting file after translation export), e.g. /%locale%/%original_path%/%original_file_name%
