Hi Crowdin Team,
I’m currently evaluating your platform in combination with the Unity3D integration and have encountered an issue that affects the translatability and safety of Unity’s Smart Strings.
Unity uses string formats like:
You have {connections:plural:no active connections|one active connection|{} active connections}
Unfortunately, Crowdin doesn’t consistently recognize or protect these plural placeholders correctly. In many cases, translators can accidentally break the syntax because the system doesn’t automatically lock or highlight the relevant parts as non-editable.
I’m aware that custom parser rules can be applied for formats like JSON, but Unity uses CSV by default, where such configuration is either not possible or very limited. Also, SRX segmentation doesn’t solve this, since it only affects how text is split into segments—not how placeholders are handled or protected.
My questions:
Is there a way to protect plural placeholders in CSV files—possibly through specific configuration or formatting approaches?
Are there any plans to improve the Unity3D integration to better support Smart Strings and their syntax (e.g. with a Unity-specific parser)?
Do you have any best practices or recommended workarounds to allow safe translation of plural strings without risking damage to the underlying syntax?
I appreciate your support and look forward to your suggestions.
Best regards, Marco
