Prefer this component to vanilla <0><1></0> tags because Docusaurus does a lot of optimizations (e.g. broken path detection, prefetching, applying base URL...) if you use <0><2></0>.
Hi @tats-u, this is expected behavior. The QA check compares the tag order between the source and the translation, but it doesn’t take grammar rules of SOV languages like Japanese into account. If the tags are used correctly, you can safely click “Save Anyway”
Right now, our QA check is purely technical - it only compares the order of tags and doesn’t take language grammar into account (for example, SOV word order in Japanese). That’s why you may see a warning even if the tags are actually correct. In such cases, it’s safe to click “Save Anyway.”
Regarding your question about AI: this is something that could be improved with AI checks in the future, but it’s not available at the moment.
