I’m having trouble exporting translations for a specific language using the CrowdIn v2 API. Previously, with v1, I could use the endpoint:
'https://api.crowdin.com/api/project/{projectId}/export-file?file=translation.json&language=hi&key={apiKey}'
to export the translation.json file for the Hindi language (code: hi).
In v2, I’ve tried using the /api/v2/projects/{{projectId}}/translations/exports endpoint with the following body, and also installed the JSON String Exporter for my user.
{ "targetLanguageId": "en", "format": “crowdin-json" }
However, if I run the API call I just get back the following There is no application found that can handle crowdin-json file type
Is there something I’m missing that I have to do before I can use the JSON String Exporter?
