Hello. I’m currently managing a project, wondering if it’s possible to have the locale portion of the export filename be in lowercase. In other words, the files are currently set to be exported as:
%locale_with_underscore%.lang
which results in filenames like:
zh_CN.lang
However the software utilizing these translated files, namely Forge modloader for Minecraft 1.12, requires the locale to be in all lowercase (and would not recognise the files if named otherwise), like:
zh_cn.lang
Is this naming scheme achievable within Crowdin? I do have ways to rename these files after-the-fact, but thought it’s best to ask if the issue can be solved within Crowdin itself.
Thank you!
