Is it Java Parser settings? Can you share the full screenshot of them? Does resetting the parser to the default configuration help?
Also, please provide me with the project name or ID (you can direct message me if you wish) and a test file so I can re-produce this behavior in my test environment.
Thanks for the screenshot and project URL, much appreciated.
By test file, I meant some file sample that has the structure/content of the file that you’re using in your project. In other words, any source file that you have will be suitable.
Would you be able to share this file sample with me? You can always Direct Message me privately.
Hi @Sefeo, did you enable this setting after uploading the file to the project? Parser configuration options only apply to new files uploaded to a Crowdin project.
