crowdin pre-translate --method=mt --engine-id=
i can’t find what to type to translate using crowdin translate anywhere docs issueses or what ever
This call should brings the Crowdin MT id
https://developer.crowdin.com/api/v2/#operation/api.mts.get
After that you can insert it in CLI or so.
I also found it in the UI, go in the UI to Machine translations, scroll down to Crowdin, and there will be a 6 digits id, like id:******
i’m not using the api i wont the id to use it via cli !
