In the editor, the “Compact strings view” doesn’t seem to be working (the strings lines wrap to new lines, displaying the entire string).
We really like how compact the deprecated “Strings” tab is, makes it easy to see a lot of strings at a glance. Hoping you can make the Editor as compact as that.
The strings tab was not totally removed and is still presented. It’s just recommended to use Editor as it provides more flexibility and is more feature-rich. But you can still work with the Strings tab without any issues.
The editor should provide a similar result if you use a Multilingual view with no Lanuages being selected.
Ha yep, that’s it. The “compact strings view” doesn’t work in that mode which was the confusing part. I’m sure you folks are working on it, but a really compact view i.e. the Strings page would be good there.
