Once the file is translated in Crowdin project, it’s sent to Zendesk and the article is saved as draft
Is it possible to publish the translated articles automatically?
I have proofreader in the project, so I’m sure that all is correct
Hi there,
Just disable the option “Push translations as the draft” in integration settings in Crowdin
Thanks! I didn’t know about this option
It worked well
