Downloaded translations don't match the current project configuration CLI error
Hi guys! We recently start using CLI and now I’m trying to download translations via CLI but the system gives me the follwoing error: Downloaded translations don’t match the current project configuration. The translations for the following sources will be omitted…
The files structure in Crowdin and config looks the same
Can anyone tell me what I’m doing wrong?
Hello! There is some mismatch in your files specified in the source/translations field in crowdin.yaml and the files in your actual project. We had the same error some time ago and in our case, the root cause of the issue was wrong export patterns.
We have export patter indicated in the translation field of crowdin.yaml but in our project the file export patterns were different. And that caused the mismatch.
We solved it in a simple way - just run the command crowdin push in order to update the export pattern of your source files. After that, the issue disappeared
Same issue here for an Android project. Not sure how to fix that. I works fine with the Android Studio plugin.
Hi @Slions ,
Linet wrote a solution in a previous message, can you please try the proposed solution? That will settle the matter
crowdin push fixed it.
What does it do? Is it documented somewhere?
Please refer to the CLI documentation for a detailed explanation of this warning - FAQ | Crowdin CLI
