Hello
As a new user, I’m evaluating Crowdin as a possible translation tool for an existing static page generated from markdown (being migrated to Docusaurus).
If you look at this PR, you will see a lot of content duplicated. Why did this happen?
Hello
And they got reverted in the [next PR: https://github.com/zazukoians/ogdch-handbook/pull/6
Hi @tpluscode
We should be able to work with Docusaurus without any issues.
Have you followed these guides during setup?
Please email us directly at support@crowdin.com (provide your project ID in Crowdin + all details about the configuration) so we can take a more detailed look at this case and provide a recommendation on how to solve it.
Thank you for your reply @Dima
Yes, I more ore less followed the Docusaurus docs on i18n. The major difference is that I eventually use the built-in GitHub integration instead of the method described in the tutorial.
I don’t know if it’s related but the unexpected back and forth changes appear in files which I converted to markdown from restructured text (the pages are migrated from Sphinx). They do need some manual cleanup to properly set up Docusaurus.
I will keep monitor if this keeps happening as we polish the sources and get back to you if the problem persists
Hi @tpluscode , sure, you’re welcome to monitor the behavior and contact us if anything
