Hi, I’ve browsed through the knowledge base, and in the project integration tab, seems there’s no integration with Shopify, or I’m missing something?
Hi, yes
Files from Shopify should be uploaded in your Crowdin project you specified in the integration
To activate it you need to use a personal access token, generated here:
