Difference Between Crowdin's Fine-tuned option vs CHATGPT's fine-tuned option?
What is the difference Between Crowdin’s Fine-tuned (beta) option vs CHATGPT’s fine-tuned option?
The difference is in the data on which the model was trained. Our fine-tuned model was trained on our internal data, while your model will be trained on your data. In the long run, your model will provide more personalized results.
