Default quotation marks in translation field of CSV
Hi! Is there any easy way to get crowdin to put quotation marks around the translation even in cases of single lines? It does it by default for multi-line ones, I just want that applied to everything basically.
(I don’t know anything about code so please imagine I am very stupid on this topic <3)
as an example, the first line is a single line one while the second one is a multi-line that has the quotations
24-08-24-00.07.20
Hi @Sapphira , let me test it. Will keep you posted
Hi Roman!
Have you had an opportunity to check this out yet?
Hi @Sapphira,
Sorry for the delay, unfortunately I don’t have an update for you yet😬 I’ll try to get back to you tomorrow with some updates🤞🏻
Hope for your understanding and patience
