Hi.
When I try to integrate Deepseek AI with an API key, I get this error. I deleted and re-added the API key from scratch, but I still get the same error.
Hi.
Hi @egmnshnky
In the field Models available for the Pre-translate please kindly select the “deepseek-chat” model to use the DeepSeek provider.
Please give it a try and let me know the result,
Hi, I’ve added ‘‘deepseek-chat’’ to ‘‘Pre-translate’’ section, got the same error again.
It should be possible to connect with DeepSeek if you follow this guide:
In case you still see errors please send us an email to support@crowdin.com so we can investigate this in detail.
All right, the issue was solved when I removed the gpt models from the ‘models available for pre-translate action’ section and added only the ‘deepseek chat and reasoning’ models.
