We use the integration between GitHub & Crowdin. However, the files shown in Crowdin for translation are not up-to-date and fully synchronized with GitHub.
Although I have synchronized the integration via the integration tab, there are still files shown in Crowdin which do not exist anymore in GitHub.
Is there any setting how I can fix it?
Thanks
Vincent
Hi Vincent,
Thanks for your message! We’re aware of the issue and are actively working on a solution. In the meantime, I kindly request that you manually remove the files.
Hi Nathalia,
Thanks for the information!
I’d highly appreciate it if you could inform me, when the issue is solved. This would be really important for us.
Thanks
Vincent
Hi Vincent,
Just wan to let you know that we have made the improvements for GitLab integration and now if the file is deleted in repo, it should be removed automatically in Crowdin as well
