So my web components have some having difficulties using the In-Context of Crowdin.
My components are protected by shadow-root, and seems that this is the reason why In-Context integration can’t read the labels to translate.
Maybe I can create something or add additional settings in order to change this?
Dima
2
Seems like you use Shadow DOM.
Crowdin doesn’t have access to Shadow DOM due to its specification, and the only solution that comes to mind is the following:
- Prepare all your web components where you have texts
- By using slots, get the text to the light DOM. See instructions below:
Shadow DOM slots, composition
This way, everything should work well.
