Can we have two crowdin accounts that are linked to the same GitHub account?
Should be possible. Like, you can’t have 1 integration to be owned by 2 users
But you definitely can have 1 repository connected into 2 project. If you use access token when connecting the integration, If using the account it may block 2nd integration because the user already exist. But I never tested this. Should be 5 mins-test, the best way to know is to try.
