Hi. A few days ago we’ve modified a few strings, the translations are preserved but need to be reviewed by proofreaders. So I want to create a task and ask proofreaders to work on them only not any other strings. How to do that? Thanks
Hi there. Actually, if you know the day when you’ve changed those stings, when creating a task you can activate the Modified parameter and set up the needed time range, so into task will be included only strings that were changed/added within selected time range. Cheers
