So , as mentioned in last one, I combine CLI and Github
In case of Github token is dead in like 7-8 months or so, but with CLI it’s dead once a month. Quite distractive, so I need to run crowdin init and do the autorization each month. Can this period be extended?
The token generated during crowdin init (authorization via the browser) has an expiration date of 1-1.5 month (don’t remember exactly, but something like that).
It is recommended to replace it with a permanent one generated in the account settings (in UI of Crowdin).
The browser authorization token you receive has an expiration period of 30 days. This means that after 30 days, the token will expire and you need to generate a new token to continue using CLI.
