CLI downloads an empty .zip without translation
Hi, have a strange issue. Crowdin’s CLI downloads an empty .zip without any translation. It contains language-named folders and it’s all, they’re empty. I don’t see any error responses while using it. What can be the case?
Just an assumption, but try checking Project Export Settings, I guess you have a lot of Skip options enabled. Or try checking config file for Skip parameters:
Yes, you know, it was project export options. One of managers just enable to skip untranslated files and unapproved stings, so system wanted only 100% green files to be exported. Disabled those options and all worked great. Thanks!
