As I see right now the time of updates is approximately 15 minutes. Can it be configured for 3 hours or so? Like in default Github integration when you select the synch schedule from 10 mins to 24 hours.
Check the update interval, i’m not sure if it’s in seconds or minutes, so best way is to try
