Hi,
Is there a way to unapprove the translation and automate changing color from green to yellow for a string whose source text is altered?
Thanks!
Hi,
Thanks!
Hi @eliogold,
When you update source strings and some of them are modified, the system shows a dialog with a list of edited strings. You’ll have the option to keep or remove approvals. If you choose to remove approvals, the color will automatically change
Similarly, when updating the source file through the API using Update or Restore File request, you can choose updateOption, which determines the action with the translation
