Can't toggle off "Require approval to join" after making project private then public again
Hello, after making my project public (I created it private first), I can’t toggle off “Require approval to join”, it was off by default if I created the project public, but now I can’t remove it. Would you be able to help me?
Hi @gtnardy
It seems it was some kind of bug since you’ve changed the project visibility from private to public and subscribed to the Free plan. I’ve corrected everything from our side, and now the “Require approval to join” is disabled in the nanos world steam project as well as in all your projects
Got it! Thank you so much!
