Hi, last time I’ve order translations from Vendor, and I know that let’s say translators M. and J. worked on it, and they was really good, no issue at all, nothing needed to be corrected, so I’m wondering if this is possible to create a Vendor’s task and assign those 2 language specialists into it? I’d like to do it.
Hello, you can create a task for the Vendor only, and after the task is received, a manager from Vendor’s side will split it between translators, so there’s no direct way to affect this process.
Still, in the comment section, you can write a note “Hi, I’d like M. and J. to do the job please” and I’m more than sure they would take your desire into account.
