Button to "Approve all plural forms" should cause jump on a next phrase?
I am often using side-by-side view and the Approve button (Alt+Enter) jumps to a next phrase after approval of a current one. That is handy. But the “Approve all plural forms” does not, which numerous times caused that i have repeatedly accidentally been approving same plural forms item.
I think that when we are used on a basic “Approve” button behavior to jump to a next phrase, the plural forms approve button should behave same way.
Hi @slrslr !
We have tested everything from our side in different Editor modes and if the option Automatically move to the next string is selected in the Editor settings, then once one form is approved by the shortcut, it will move to the next one.
If the system behaves incorrectly from your side, please share with us the video record directly to support@crowdin.com
Thanks,
