Just wondering which one will be better for translating terms from glossary, this option in project setting (webURL from knowledge base) Glossary | Crowdin Documentation
Or this application (from crowdin store, installed as custom integration) Discover the right solution to enhance Crowdin experience
What’s the difference between them? Shouldn’t they be the same?
