We have web-based app which is currently our only project in Crowdin, but are looking at developing another webpage which would serve as a digital “user manual”. Is it better to create another project in Crowdin or could the manual also be housed in the same project as where we manage the translations for our app?
Hi there,
It depends on your preferences, if the domain is not changed, the Wix Proxy integration can be updated accordingly and a new page will be included into the current project setup:
Alternatively, you can consider a CSV-based approach:
Hey Dima, thanks for your great and rapid response. Could you expand a bit on what you mean by “csv-based” approach?
@dtrapp you can use CSV files to proceed with Wix localization. This process will be a bit manual, you will need to download CSV from Wix, upload it into Crowdin, do the translation, download the translated file, and upload it into Wix. You can check the weblink I’ve shared, it has more detailed instructions.
