When I try to connect crowdin with azure account Selecting Repository is opening, but after 2 seconds it closes and this toast appears
Check the limits, maybe your branches are already reached in Crowdin (Files).
Or the token scopes. Do you use full-acess admin or owner token? Simple maintainer is not enough. Is Crowdin added into allow-list from Azure side?
