Automatic Language in header for Multi-language CSV export?
When I build and download a project that is built with a Mutli-language csv, is there a way of getting the the language name into the first row?
Like how it says “English” under source string?
Thanks
Hi @Svavelstickan , once you build the project, you get the file named, inside the file you can see only the source content
