Auto-approve duplicates in source text review
Hi,
We would like to use the duplicate functionality when doing source text review. Is there a way to auto-approve source texts with a 100% or perfect match?
Alternatively, it would be a help if I could filter for perfect matches and then bulk-approve these.
Hi @JosefineFranck,
The 100% or perfect matches are applied to the translations made by TM. In the Source Text Review step, you need to review the source text. In case you enable the option to Hide duplicates in the project Settings → Import, then the duplicated strings will not be available on any workflow step. The changes you make to the master string will be automatically applied to the duplicates.
