Approve all strings for a particular document?
I found that the automatic translation is generally 95% good, so it would often make sense to immediately approve the entire document, then maybe go into the details and change a word here and there.
Does Crowdin currently support this? I assume it does but I couldn’t find any option for it. Any information would be appreciated
HI @laurent22 ,
Currently, there is no option to auto-approve translations made with the Pre-translate via MT option. This is because auto-approval of translations, particularly those from machine translation, could potentially lead to inaccuracies in the final translated content.
As a workaround here, you may try to batch-approve all translations at once in the Side-by-Side view in the Editor. Kindly check the screenshot with an example on the matter:
