I am using Android Studio with Crowdin plugin and it has been working for several years. I updated the Crowdin plugin to v2.0 and it’s not working any more.
First thing: The v2.0 plugin did not find the configuration file. I renamed the old one which was working. That old one was not compatible with the new one. So i had to adjust it according to crowdin property topic in knowledge base. The plugin gave good feedback of what was wrong with the configuration file. So I fixed all issues.
Then after every issue was fixed I got this error message:
Error from server:
Nothing more. So nothing is working and I have no clue what is wrong.
This is my configurationg file:
"project_id": "project_id"
"api_token": "my_new_personal_api_token" #can be found in your project settings page
"base_path": "my_path"
"files" : [
"source": "/app/src/main/res/values/strings.xml", #source files filter
"translation": "/app/src/main/res/values-%android_code%/%original_file_name%", #where translations live
"languages_mapping": {
"android_code": {
# crowdin expects directories to be like 'values-uk-rUA'
"de": "de",
"no": "no",
"fr": "fr"
The configuration file I used before was this one:
project-id=my_project_id
api-token=my_api_token
disable-branches=true
If I use this configuration file, then I get this error message:
class java.lang.String cannot be cast to class java.util.Map (java.lang.String and java.util.Map are in module java.base of loader 'bootstrap')
