AI Rate limit reached
Hi team,
We’ve top-uped balance for AI translation and trying to pretranslate 112 strings from Italian (project BSC Designer dashboard in Crowdin), but getting Rate limit reached error:
“message”: “Rate limit reached”,
“aiPromptId”: 21381,
“aiPromptTitle”: “Pre-translate”
API key for OpenAI is entered and limits usage look good. Please, advise, where to look to understand the root cause.
Hi @4savkin,
The token limit per minute has been reached. If possible, please consider increasing the limit on OpenAI’s side. Alternatively, you may want to pre-translate strings in smaller batches in Crowdin.
Hi Olena,
Is there any setting on Crowdin side to adjust the size of batch for pre-translation? Also, I’m not sure it’s token per minute limit, as from 112 strings for translation no string were translated. 112 strings are far from reaching the limit.
@4savkin
Please let me know if you have tried to run the pre-translation to all 9 target languages at once?
To use the AI pre-translate in batch you can open the Editor → Side-by-Side view → select the strings that need to be pre-translated → run the pre-translate for the chosen strings:
Please try translating a batch of strings and let me know the result,
Did not help… The message “Pre translation in progress…” pops up, but then another message says “Nothing was pretranslated”. Trying with 1-2 lines so doesn’t look like limit issue.
Hi @4savkin,
As far as I can see from my side it is still the “Rate limit reached” reason. Have you tried checking this setting on the OpenAI side? https://platform.openai.com/docs/guides/rate-limits/usage-tiers.
Thanks will look more into the limits issue.
