Dear support,
I have 2 questions:
Cost Estimate: If I upgrade to Pro Plan, how do you estimate words? For example (From EN-CN): 1) This is an apple. 2) This is a big apple.
There’re only two different words between String 1 and String 2. If I have translated String 1 before and only need to translate String 2 for this task, how to calculate the cost of String 2? Will the cost of this task deduct the same words in translation history? How do you calculate words in detail? -
We used UE4 as the engine. What should I do to connect Crowdin with UE4? This means when I finished translating in the Crowdin, how to make the latest translation show in the UE4 without exportation/importation.
Looking forward to your reply.
