Hi, any chance I can use MT + TM pre translate as 1 option? Like, I’d like to be able to run within 1 request MT translate for lets say German and Spanish and TM translate for French. Is it possible to somehow configure to work with 1 button only?
You can use some automated options out of the box, like Advanced Workflow with auto Pre translate:
Or, create your own CI using our API:
https://support.crowdin.com/api/v2/#operation/api.projects.pre-translations.post
Alternatively, the Enterprise version offers more flexibility on the matter, you’re welcome to use 30-day free trial and give it a check:
