Hello. Working with approvals kinda hard, because of when you click the “Approve” it’s good only when the suggestion doesn’t have any QA issues. If it has, you need to click “Approve” and then “Approve anyway” and then you need to reposition the cursor of your mouse or touchpad. If it’s 300+ stings per one sit, you need to reposition cursor 300 times. Any chance I’m missing something and there is some easier way?
