Hello,
I am a translator working for a localization agency that uses CrowdIn, which means I only have access to translator functionalities. I’m having two issues with a project that has a lot of duplicate and numeric strings:
1- Duplicate strings with no auto populate function. There are 100 pages of strings that look like this:
String A
String B
String A
String B
Is it possible to automatically populate all strings with the first translation we assign to each one, and then automatically approve them all? If not, how do I proceed without having to manually add the translations for each string?
2- There are another 100 pages where the target should be the same as the source since they are composed of just a sequence of numbers. Here I also don’t see an option to batch-populate the target strings with the source content.
Could someone advise on how to proceed with this? Is there at least a shortcut to copy the source text into the target text?
Thank you!
