Hi, I’d like to know is it possible to set up and automate pre-translation to my files.
I’m adding them 4-5 times per day, and rum the pre translate each time is not the best solution.
I would like to use DeepL engine for the pre-translation.
Thanks for help.
@GeorgeTh a scheduled pre translate you can set up via API, but I guess in your case it would be better to use just a workflow (Resources → Workflows)
In the Machine Engine section add your access key to the Translation engine
Than go to workflows and create one
Any next time you upload new files or stings, they would be automatically translated by Machine Engive
